Anyone managed to set one up and get it working.?
I have got a seperate hall effect speedo sensor looking at the prop bolts and this seems to work ok. However I think its the Revs input that is giving
me problems.
If anyone has this setup, what wire did you connect to in the loom?
Many thanks
jon
if you give Acumen a call they will find the wire you need if no one else gets it first.
the dedicated rpm wire on the 893 ecu is the yellow with green trace
regards
I know of not one person who has got any GI to work with this engine successfully
