As title.
A picture of the Grey plugs (2005 model ZX12R) where the PC III connect would be most helpful.
As I chopped these out by mistake.
What I need to know, is which side does the to socket and plug go.
Thanks in advance Martin
The power commander lead bridges the two plugs on the loom. The power commander male goes to the throttle bodies and the PC female to the loom. It will be difficult for you to patch in I think. On my power commander all the wires are black...
Luckily I kept the two grey plugs.
Just need to re-fit them.
There is often confusion with the term male and female connectors.
Some refere to connectors with pins as male, and sometimes the shell socket with pins as female.
So I'm currently no 100% sure which is which.
Don't want to reconnect 32 wires only to fine they are back to front.
Martin
