As you probably know the overflow hose to the expansion bottle on the Fireblade comes from the radiator neck.
The radiator I'm using doesn't have an outlet in that position, where should I take the hose from?
Chris
[Edited on 7/5/09 by chrisg]
Mine are from the top of the rad and also the top of the thermostat housing.
.......but I don't have an outlet on the radiator.
Chris
i just use the one from the top of the thermostat housing, this setup was from diagram of someones blade setup a few years ago, chris gamblin?
