Hi all. I purchased my car with the main reason being track days. The problem I am up against is noise. I am going to get the car noise tested so I
know which tracks I can confidently book into.
I will probably change to a repackable exhaust but in a blade what is the most realistic noise limit I can aim for?
Can any of you running an 893 blade let me know what your current db level is and which exhaust you are running to achieve it?
Thanks all
I cannot tell you what the DB level is on mine but with a gutted straight through R1 can it is LOUD.
I also have a standard R1 can which subdues things, the intake is also very noisy, if you lose the factory air box, mine is now ducted away to the
front which made more difference than the exhaust.
You can also do things such as point the exhaust under the car.
Lydden hill is noise friendly so have a few goes there to start off with.
Regards Mark
I don't remember the figures but mine passed sva with the MK exhaust and a standard air box.
I am told the best way to get the noise levels down is with an AB Performance air box. Give Andy a ring im sure he will help you.
Hope this helps
Dave
SVA'd at 98dB with standard airbox and R1 standard can (with a 90 deg exit bend)
as OK for Donnington @98 too
Looking out for a bandit can, they're quieter still.
Currentlr running (road) a Viper can and that's 'kin loud
mines a 919 which i wouldn't of thought would be any different and i was measured at croft last year at 100db. thats with an airbox and a 5" repackable exhaust.
Passed the noise test at SVA last month at 101db @ 7500rpm. Stuart Taylor supplied 5" exhaust can and open inlets (ie. No airbox or filters
etc.)
Surprised or what! Thought it would definitely fail.
I failed SVA with MK standard silencer at 103db, I have now fitted the larger MK silencer with built in "cat" and it reduced it to 98db, hope that helps. Barry
Originally posted by f1ngers
Passed the noise test at SVA last month at 101db @ 7500rpm. Stuart Taylor supplied 5" exhaust can and open inlets (ie. No airbox or filters etc.)
The 893 is a fairly quiet beast, as far as bike engines go. With an airbox fitted, particularly, you'll get sub-100dB on any static test with a
single bike can exhaust. It's surprising how noisy things get with just a few cc added, but at 893 things are manageable. Competition events
require 105/110 depending on circuit restrictions, SR's, etc.
The problems start when you get a drive-by measurement, or a 'test' or 'track day'. The latter are sometimes 98dB static, which
you might just get through, and that'll be it. Cadwell et. al. are your friends here. Circuits like Combe and Goodwood and the drive-by becomes
an issue, the NIMBYs have really got the circuits over a barrel. It's really difficult to get any bike engine through a properly metered
drive-by, especially if the wind is against you. Book a test or track and go see.
Most circuits are fairly good about it all, they'll often have 'average' noise quotas that the council (etc.) have set, so you'll
end up out with Mondeos on a track/test day.
Did it run properly?
Mine wont pull/rev properly without an airbox!
Interesting post!
I run a 918 in mine. Will get a 2nd lump as a spare cos there so cheap.
Mine has a TTS filter/jet kit and universal 'cherry bomb' silencer with 90 degree bend. I read around 105db on my cheapo fleabay reader. Its
quite loud though and Im currently getting MAC to fit a quieter can
for a temporary measure - or quick fix for tough circuits you could use a 'DB eater'
you can get them on ebay etc... some are better than others.. but they do work - i got my blade engined striker (with AB airbox) through donington
with it - without it i was going home..
you can get them on ebay etc... some are better than others.. but they do work - i got my blade engined striker (with AB airbox) through donington with it - without it i was going home..
Thanks for the input guys. I'm looking to start off with buying a bigger exhaust. I'm either going to get one from MK, Car Builder Solutions
or try 907 from this site as advertised on the special offers thread. Can anyone recommend the best place? I'm guessing I need to buy the biggest
one?
Gixermark, are you refering to something like the BOLT-IN SILENCER BAFFLE from CBS? It carries a warning about engine performance, what does it
mean?
Thanks all
I know on the mx'ers it felt like the bike was being strangled. I wouldnt rev out as clean and felt flatter on power mid to top but these are
single cylinder 4 bangers revving to 12k+ RPM
An inline 4 BEC maybe different??
Originally posted by asl
Thanks for the input guys. I'm looking to start off with buying a bigger exhaust. I'm either going to get one from MK, Car Builder Solutions or try 907 from this site as advertised on the special offers thread. Can anyone recommend the best place? I'm guessing I need to buy the biggest one?
You know what worked for me ?
A home made airbox (to get under bonnet) with std blade filter element. An airbox of some kind I think is needed to keep noise down, the intake noise
on bike engines is possibly as loud as the exhaust.
Guess what I used on the exit side........
A std blade can, back to back on dyno the std can whilst down on outright power gave a much better power spread and was much more drivable around
town.
OK I admit it, from time to time in hooligan mode the race can came out...........
db eater worked fine on mine, saves either having a heavy restrictive can on all the time, or swapping cans between tracks etc to suit..
temperatures were absolutely fine, and performance was barely if at all noticeable..
you could try a std blade exhaust from the bike, but for £15ish its handy to have a db eater in your spares box anyway..
as with all these things you'll get 101 opinions from the armchairs around the country, and althoug hthe DB eater ain't a
'solution' per say... it will get you through and work if.when required
Originally posted by dean100yz
I know on the mx'ers it felt like the bike was being strangled. I wouldnt rev out as clean and felt flatter on power mid to top but these are single cylinder 4 bangers revving to 12k+ RPM
