Hi,
Save me leaking fuel everywhere, does anyone know the ID of the fuel line I'll need for an 893 blade? Its running off an carbed r1 fuel pump.
From what I can gather the fuel pumps OD is 10mm, so the fuel pipe "should" be 10mm ID. I just want to check before I order the wrong
stuff!
Cheers guys and girls!
Really? That sounds huge. R1 was 6mm if memory serves me right!
I just measured a spare bit I have here and it's 8mm ID. It's the original Honda grey stuff with the red stripe which I have from the filter
to the Honda pump and from the pump to the carbs.
Honda pump connections are 10mm OD so 8mm pipe expands over the 10mm ok and presumably maintains 8mm throughout the fuel system.
[Edited on 28/5/09 by f1ngers]
cheers!
As above def 8mm
