I used to have a micra radiator in my MK indy (zx9r) however the radiator had an argument with an immovable object and is now broken.
So I am trying to way up the pro's and cons for either replacing the micra radiator (easy fix but expensive radiator) or opting for a polo
radiator (cheaper radiator, but will involve replumbing the cooling system).
the Micra wroked fine, has anyone else had a similar issue? or thoughts?
Is there really that much of a difference cost wise?? I would have though the cost / hassle of re-plumbing the system would cancel out any saving to be made with the polo rad. Either way they're both tried and tested staples in 7's.
Go for what you know fits and works , as it will possibly cost you less in the long run plus you know its what you really want a quick fix and back on
the road smilling yes.
Mike
If it works why try to change it ?
get another Micra rad imho
If you haven't already try these guys.
They offer Micra rads between £40 - £130 depending on model.
Click on the specific rad for dimensions.
www.carcooling.co.uk/index.php?p=home
Cheers, Pewe
As a matter of interest what year Micra/model are they from as a few on ebay for much less than you quoted.
Mike
Cheers, Pewe![]()
Mike, it si a K10 series, with the radiator cap on the side, rather than in the middle. 998cc L from a 85 I think.
I have not found any on ebay so far.
cheers
Craig
Mike
Have look here Craig as they list the dimensions too plus prices not too bad either.
http://www.micksgarage.co.uk/CarSpec.aspx?mode=drilldown&DeptID=149&Make=Nissan&BaseModel=&Year=&Engine=&PetrolDiesel=&Typ
eID=
Mike
http://www.micksgarage.co.uk/proddetails.aspx?pid=174929&pk=91F28
[Edited on 16-6-2009 by miikae]
Thanks Mike, that looks brilliant.
cheers
Craig
Whats up with Scrappies??
Bob
I've got one here. It's a used one that came off a running car with no leaks. That is I installed in my 7 and used it to run up the engine
etc. but replaced it with a new one that I picked up cheap. It's the one with the cap to right hand side when standing at the front of the car. I
was keeping it as a spare but it's yours if you want it and i'm probably not too far away.
Oh yeah it's a Micra one
[Edited on 16/6/09 by f1ngers]
Fingers, you have U2U.
cheers
Craig
just a quick thumbs up to F1ngers. thanks for the Rad. will hopefully get the car back on the road soon and hope to see you at some meets soon.
cheers
Craig
