Hello all, just wondered what I should set the shift light I have just fitted to on the Mk Indy? It is running a 99 R1 engine.
Lee
Surely someone must know when peak power is delivered, think I may go for 11500rpm....
Lee
Around 10ī500rpm....
Also depending on your intake and exhaust side how well it pulls att high revīs.
An quick exercise at an rolling road would give the specifics for your set-up and also good info if the engine would like moore or less
fuel....rejetting and needle set-up...If itīs standard you would see aprox 120-127Hpīs on the wheels if everything is in order an not very muffled....
