Now that my car is on the road (except for waiting for new clocks) I am looking at getting a gear indicator, can anyone recommend a good and easy to
install gear indicator
I am sure there was a thread on this a while back but for some reason I can't find it
Ive just purchased, and fitted a Healtech GIpro (X-type) to my R1 engined car. Couldnt be simpler to configure. Definately recommmended
i too have a girpro on my zx10r, realign a few wires and your away no need for extra sensors
realign a few wires!
not sure my limited wiring ability would cope with that
These work better with injected engines or Carb ones?
2003 5PW fi R1 engine
I have a Acumen installed. I had to tap a decent feed for revs as I was unable to locate my ECU revs Tacho wire so we tapped into injector 1. Then t
off the prop magnets feed for wheel speed pulses, tapped into the neutral light and then a nice earth and ignition
Works great, although it takes about 15 meters to display the gear after its been selected
Think mine is a Techtronics unit - very easy to fit, plugs into the gear position output from the gearbox, and includes a built in Timing Retard Eliminator to boot.
on the yamaha engine you plug into the speedo sensor with a pigyback y splitter. all you have to wire up yourself is a switched +ve for the power, and
splice into the crank sensor which is easy to find. its a cream/natural colour 2 pin plug near the gearbox. you need the grey wire
Originally posted by Davey D
on the yamaha engine you plug into the speedo sensor with a pigyback y splitter. all you have to wire up yourself is a switched +ve for the power, and splice into the crank sensor which is easy to find. its a cream/natural colour 2 pin plug near the gearbox. you need the grey wire![]()
if you have a 5vy engine, and need a pic of the exact plug for re-assurance, then ill take a picture of mine for you
if you have a 5vy engine, and need a pic of the exact plug for re-assurance, then ill take a picture of mine for you![]()
Can you advise how easy it was to fit when you get it as i'd like to get one too.
