I have a friend doing a BEC conversion on a car and he asked where I got my prop flange adapter for my Busa. This is the component that replaces the
chain sprocket on the standard engine.
Mine came from Westfield so was sourced for me. He needs one splined to suit a GSXR1000 and ideally undrilled.
Does anyone know where they are available from?
something like a sprocket adaptor?
Try http://www.sprocket-adaptors.co.uk/
Matt
Second for Sprocket-adaptors.
Cheers guys
Slightly different but I was trying to fit mine today - cant get the old sprocket off though as cant undo the nut. Any suggestions? 05 R1 engine.
You need to jam the sproket so it doesn't turn. Check your manual to see how to do it.
Yes use an impact wrench with the engine in gear, other wise you just end up spinning the sprocket freely.
Many thanks gents. After a couple of hours struggling with it earlier tried your suggestion and was undone in about 10 seconds !
