Some differing debate on the emission levels required to pass SVA.
Its a 2005 ZZR 12.
0.3% CO, 200ppm HC ?? what lambda?
Can someone give me the definitive answer, or a link?
I await the LB BEC gurus !
[Edited on 10/9/09 by Jumpy Guy]
between 0.97 and 1.03
[Edited on 10/9/09 by dan__wright]
so-
CO- less than 0.3%
HC- less than 200 ppm
Lambda - between 0.97 and 1.03
That right? Anything else?
Discussion at work was that CO level was 2.2 %.....
Fast idle test (2500-3000prm)
CO <0.3%
HC <200ppm
Lambda 0.97-1.03
Idle test
CO <0.5%
adrian
PS. God knows where someone might have come up with 2.2%CO
hi there Jumpy,
There is an IVA manual that you can download at
link
Its a good resource if you want the absolute truth that you can wave at th examiner when he starts putting crosses in boxes.
Matt
Thanks guys
Im not doing IVA, im doing an SVA
Not sure if the emission levels have changed?
