Emissions are sorted!
Dangle_kt - 2/10/09 at 06:42 PM
Went and bought some standard pilot jets, mains and needles and had it looked at today.
CO is now less than 1% and HC's are 800 ppm! WOOHOO!
SVA on monday so once I have fitted the speedo healer which arrived yesterday I'm sorted!
Can;t beleive I am going to pass my SVA at last! *GULP!*
adithorp - 2/10/09 at 06:58 PM
Nice one. Fingers crossed for Monday.
Although it's within the HC pass limit, 800ppm is still high though. Worth trying to get it sorted one SVA is out of the way.
adrian
Dangle_kt - 2/10/09 at 07:27 PM
I think I might be burning a touch of oil, or maybe I need new plugs, the ones I have fitted are used ones from Lee who helped me out with an old set of his when mine started running on 3 cylinders!
I'm considering running a sausage filter and refitting the older bigger jets after SVA and getting a good power setup on a RR.
speedyxjs - 2/10/09 at 07:30 PM
Nice one. Good luck monday
blakep82 - 2/10/09 at 11:52 PM
awesome! hope you do pass on monday!
getting annoyed with these sva fails
sure you will pass this time now
McLannahan - 3/10/09 at 12:11 AM
Good Luck! (fingers crossed!)
t16turbotone - 3/10/09 at 06:17 AM
Good luck mate...!
mangogrooveworkshop - 3/10/09 at 08:28 AM
Change the old plugs and use a fresh set for the test. Mac1 did that and we got a much better pass. Plugs dont do well in short starts not getting up to heat situations. Seems the more you use them the better they work.
Good luck
Just a pity the crap weather is here now....for at least 5 months
