Can a ZX12R Fuel Pump be used for a ZX10R engine?
Steve Hignett - 18/1/10 at 08:00 PM
Hi All,
(as above)
JoelP - 18/1/10 at 08:10 PM
carbed or injection?
yorkshire-engines - 18/1/10 at 08:16 PM
carbed or injection? cumon Joelp
the early zx12 CANNOT be used its a pump only no reg you will over feed the inj rail
the later 03 on can be used as it has built in reg the zx10 pumps are around £50 and are much smaller than the zx12
not seen a carb model yet
cheers malc
Steve Hignett - 18/1/10 at 08:40 PM
I believe it's a 2004/5/6 ZX12R pump and it'll potentially be going on a similar age ZX10R...
bigrich - 18/1/10 at 09:10 PM
12r pump should be ok, not sure if the level sensor setup is the same.
you can also use the zx6r FI pump. this is what i used and is compatable with the zx10r clocks fuel warning.
zx6r pump cost me 20 quid from the bay still in the tank (damaged).
TimC - 19/1/10 at 08:32 AM
Clocks not being used, and you're not a real racer unless you're checking the fuel level with a stick.
