Power Commander zero values
bassett - 24/1/10 at 10:42 AM
Hi can any one confirm that if a PC3 is set with all zero values it will run as the ECU was intended?
Adam
Richard Quinn - 24/1/10 at 10:53 AM
Allegedly! The + and - values are nominal changes from the stock value so a value of 0 should correspond to stock.
bassett - 24/1/10 at 12:50 PM
cheers i thought it was just wanted to make sure
