This is a Question for all u people using the ZX10R motor
What diff ratio are you using and what revs do u pull at about 70 to 80 mph plus the top speed Please
Will help me decided what engine will go in the Indy next. It needs an upgrade, to slow now
Kev....
17 inch wheels
zx10r 3.14 diff 74 mph in first gear at 12000 rpm
and bout 5-6rpm in 6th
I know andy w is using a 3.14 but i dont know about the revs
Sorry
Jacko
BTW if you want a Sierra 3.14 go to Sweden, Still £250 but loads to choose from
iv used a freelander diff,it does 7000rpm at 70mph,not sure what the ratio is though.
hi
here are the gear ratios,
Primary reduction ratio 1.611 (87/54)
Gear ratios: 1st 2.533 (38/15)
2nd 2.053 (39/19)
3rd 1.737 (33/19)
4th 1.524 (32/21)
5th 1.381 (29/21)
6th 1.304 (30/23)
Final reduction ratio 2.294 (39/17)
if you input them into the speed calculator on this site that will give you an idea,
i run a 314 with the turbo zx10r engine and seems a bit tall for 1st gear imho,
338 works well over the gears and around 125 top end on 15" wheels
cheers
sean
Will help me decided what engine will go in the Indy next. It needs an upgrade, to slow now![]()
Kev....
. I'd deffo steer clear of 04-08 R1 engines I've seen too many let go usually conrod failure
. GSXR 1000 motors are very
strong and have an excellent gearbox and from 05 were fitted with a slipper clutch same as the ZX10r.
Freelander 3.21 diff on 205/60/13 rears shows 69 in 1st and 135 in 6th, all indicated on speedo ( on a private track
6th gear gives roughly 10 mph per 1000rpm on the above.
Thanks all for the reply's its a toss up between the zx12 or 10 just wondered about the gearing on the 10 as I've got 3.38 diff and
didn't know if u needed a 3.14 or not
Kev.........
338 is fine
link to a video of zx10r with a 338 in it
looks good to me on track
http://www.youtube.com/watch?v=-rNfrtbsKaY
sean
have some one try to put the zx6r tranny into the zx10r? looks the same, first gear is shorter and 6e gear is taller!?
why does no one replay
