paddle shift???
boggle - 7/4/10 at 02:23 PM
how easy is it to fit a paddle shift system to a sierra colomn??
will i have to loose the switches etc???
barry
blakep82 - 7/4/10 at 02:26 PM
yep you won't be able to have both paddles and switches on there, unless the collumn's REALLY long so the paddles and switches don't hit each other at any point
adithorp - 7/4/10 at 02:41 PM
Most people loose the switches and steering lock, but it has been done and kept them.
adrian
jimgiblett - 7/4/10 at 02:50 PM
I have a paddleshift and a single stalk setup on my Fury. I have had to attach the stalk near to the dash, it is easy reach though.
The difficult thing was finding a right hand "lights and indicators" stalk (which I needed as the push-rod goes down the left hand side). 1980s Nissan Micra came to the rescue.
Some people put small latching switches on the actual steering wheel and wire up using curly cable and connector.
Paddle shift is fairly simply if you have access to a lathe. The key part is the sleeve. Have a look in my Fury pics for dimensions
Sleeve1
Sleeve2
I turned down the column so that it was almost an interference fit when the collar was slipped on.
Drop me a U2U with your email address and I can send you some more pictures.
Jim
boggle - 7/4/10 at 02:52 PM
cheers peeps....
as i dont need to iva the car im thinking all i need on the colom is indicator and main beam???
i can put the lightswitch on the dashboard??
Davg - 7/4/10 at 02:58 PM
Barry
As said above by the guys. You can also make a take off plate to mount under the column (if you want to retain the Sierra switches etc) tvia the tapped holes and bearing off the plate with paddle levers comminh up from there. Loads of stuff on here 'Search is your friend'
cheers D
boggle - 7/4/10 at 03:17 PM
looking throu the search bit i see reference to an electronic paddle shift???
is this with the use of solonoids???
Hellfire - 7/4/10 at 05:31 PM
The paddleshift we fitted retains all the Sierra switchgear. You could easily lose most of the switches and put them on the dash but losing the indicator stalk would be a pain in the ass.
[img][/img]
jimgiblett - 8/4/10 at 10:37 AM
Thats a very neat paddle setup does it flex much?
I agree indicators and main/dipped are a pain if not on stalks.
- Jim
[img][/img]
boggle - 8/4/10 at 11:06 AM
so can this be done electronically??
adithorp - 8/4/10 at 11:20 AM
Yes it can. Using a quickshift kit with actuators. I think most still put a gearlever in though as back-up/to find neutral.
adrian
jimgiblett - 9/4/10 at 10:17 AM
I would be a little worried with using quickshift actuators on a blade as the selector forks aren't the strongest. If purely a competion car then maybe, but not on a road car.
- Jim
boggle - 9/4/10 at 11:30 AM
i think first off i will use cables, then move to that idea at a later date....
going to make the paddle shift today...
