Who does, or can do, an R1 engine cradle that will fit into a Mini subframe?
Or is it just a case of welding engine mounts at the right place?
Final one, who could make the sprockets etc needed to transfer power from gearbox to mini driveshafts (just like pro-motive's setup)
Mk engineering [ Martin ] or
Zcars
Jacko
Seen their price list then
Chain drive diffs can be got from http://www.westgarage.co.uk/services/chain/chaindrives.html
(If you check out their logo you may find a similarity to an avatar
on here)
[Edited on 19/4/10 by iank]
Originally posted by iank
Seen their price list then![]()
(If you check out their logo you may find a similarity to an avataron here)
Will contact Mk to see if he can help if not too busy.
[Edited on 19/4/10 by mid-buggy]
That went a bit wrong.
Martin at Mk engineering, will definately be able to sort you, well i'd be very suprised if he could'nt.
Lynx AE also did one in the front, and another one i can't remember.
Zcars i would rank the best...
you can buy a full kit including, well, everything for a rear/mid engined mini for around 10k for the R1, or 7k for a volvo engine...
includes roll cage, suspension, engine, everything the engine needs to work, diff, front suspension, fuel tank...
http://www.zcars.org.uk/mini/volvo.htm
try pro motive
http://www.pro-motive.co.uk/R1KitInfo.html
if you change te engine position on a mini technically you need an i.v.a.
Originally posted by boggle
if you change te engine position on a mini technically you need an i.v.a.![]()
