Does anyone have instructions on how to use the 3 buttons on the faceplate of a power commander? Want to lean-out the MoTable range for MoT tomorrow, but have no instructions and can't get the powercommander to talk to my laptop - so stuck with the buttons and no clue!
unfortunately all those links are dead
From memory...
1. Press and hold all three buttons and then switch ignition on.
2. Release buttons and press the one corresponding to the range you want to alter. By repeatedly pressing you'll see the tell tale LEDs move up
and down.
3. Stop pressing when it's at that level you want.
4. Repeat for any other area you want to alter.
I think there's a time limit between stage 1 and 2 so be quick. It'll take a while to get the hang of it.
adrian
Thanks adrian - with your guidance I've figured it out....for reference you push the button to make the display go up, hold it down to make it
drop....
So fingers crossed if i put the low range down significantly it'll be enough to get through the MoT...
