Does anyone run an uprated clutch on their 2002/03 R1
I replaced my clutch during the winter with a Barnett Conversion (with Race Springs) and new genuine plates from Yamaha, but after a very spirited,
very early morning 2hr drive today, it has started slipping again.
My engine is an ex-race bike engine and is up from the standard 150bhp to 180bhp, and I am wondering if the standard plates just can't take the
extra power & extra weight of the car
Anyone have any ideas, I don't want to have to keep changing the plates
what oil are you using ?
I am using the correct oil, it has been fine since I changed it and it has probably done 300/400 miles
im sure my biker friends swear by fuchs silkolene to reduce slip. What oil do you currently run?
Out of interest what mods help it get to 180bhp, me want!
Out of interest what mods help it get to 180bhp, me want!![]()
The barnett race springs are a bit cheesy. Better to use the standard road ones and a copper washer under the spring seat to give it a bit more
clamping pressure.
If your steels are blued they can be revived using those green saucepan scourers. Were your plates soaked in oil before being fitted?
Personally I use Castrol Power 1 since it was recommended to me and have never had any problems.
- Jim
Even though your engine is uprated, I think using two diaphragm springs is worth a go - it certainly cured my clutch slip.
I have the 2003 R1, 5PW with Barnet clutch fitted 200 miles ago.
No probs with slipping even with a passenger, sticky tyres and giving it plenty of beans.
Only thing it could be is wrong oil or not set up right?
Thanks for the replies, as I have said I have ran the new clutch for 400 miles or so including two up and running Toyo 888's, and have had no
problems at all so am confident in the Barnett Conversion.
The original clutch started slipping almost straight away once the car was built and on the road, and the conversion/new plates did resolve the
problem.
The run yesterday was very hard and full on for 2 hours or so, so I assume that maybe the clutch had just got too hot or as some have mentioned maybe
the Shell oil is not that good.
I think I may do an oil & filter change and see what happens, as soon as it stared slipping I backed it off so hope that I haven’t damaged the
plates..........otherwise its another engine out job!
- Jim
Quite a few people recommend that the R1 clutch does not like fully synthetic oil & only semi should be used, maybe it could be that?
Mine has a heavy duty diaghpram spring plate & I use Silkolene Comp 4 semi synthetic and have had no problems at all.
When you soak the plates, its a good idea to use plain mineral oil or a semi synthetic oil (which is mineral anyway...) rather than fully
synthetic.
After that, any good fully synth bike oil will be OK. I personally rate Motul and Castrol
- Paul
Right then, I have ordered the new plates and have just bought 5l of Castrol Power1 fully synthetic.
Hoping to swap them over at the weeked, subject to the dealer getting the plates in - so what is the right way to do it:
1 Soak in Silkolene Comp 4 10-40 semi syn which I have on the shelf
or
2 Soak in Castrol Power1 fully syn
3 Leave for at least 24hrs
4 Fit
Any other advice, as I don't want to be doing this again in another couple of months
I dont suppose you want to sell them old plates if there ok looking?
I dont suppose you want to sell them old plates if there ok looking?![]()
but would be very concerned that if someone fitted them they would slip, I did read somewhere that once they have started
slipping then they will just start to get worse and worse I'm using Barnett + race springs (the new ones - Barnett exchanged the old ones for free) and synthetic oil. After the conversion, I just did one
trackday, so can't promise on longevity.
I did coat (not soak) the plates before fitting.
Before that I was using 2 diaphragms, which did very nice, until a very very mad night at a track
I did the conversion as I plan to turbo the engine later on... else I wouldn't.
Joao
I have just collected the new plates and they are now soaking in a bag of nice Castrol Power1, hoping to pull the engine out tomorrow and get them changed..........and hoping I don't need to be changing them again!!
do you 'need' to take the engine out ??
the cover certainly comes off without taking it out, oil doesn't need draining either.
GeorgeM
GeorgeM
All done
, I just hope that after 24 hours of soaking the clutch will be OK this time
Originally posted by spdpug98
Jim, are you using the Castrol Power 1 Racing or Power 1 GPS
I have been told on good authority that you should never run a R1 engine of fully synthetic oil for exactly that reason - Clutch slip!!
