Hi
I have a question regarding the clutch on an r1 (4c8 -07). I´ve drove the bec for the first time today, and the clutch is weary "heavy" and
i dont get any feeling at all. I have never driven an bec before, so it might be ok!?
regards Henrik
how far from the pivot point on the pedal is the cable atached? I've had the same problem with mine, I moved the cable 10mm closer to the pivot
on the pedal and now I can push the clutch in by hand
Thanks for the tip...
I will try this tomorrow...
/ Henrik
