oil pressure on blade 954?
Gordy - 4/7/10 at 12:13 PM
when engine is running hot (seen up to 110deg) using max revs in hot weather then backing off for junction, traffic lights etc at idle oil pressure light flickers with about 10 psi showing on gauge but with any throttle light goes off and up to 85 psi with full throttle, i use castrol racing 10/40 fully synth oil, only happens in hot weather, any ideas?
bigrich - 4/7/10 at 12:24 PM
sounds pretty normal to me, 10 psi or less at idle with a vey hot engine is'nt unusual.
my old 919 blade car used to drop towards 7 or 8 psi when hot
Gordy - 4/7/10 at 07:05 PM
Cheers mate
