After the above just trying to work out how much aggro/hassle/pain in the butt it will be to swap engines from an 05R1
the more piccys the better
hi there is one in my archive if any good,
lots of money to do this conversion,
engine easy 2k -2.5k
manifold £350
Billet modified sump£750
remote filter housing£150
oil cooler£100
pipe work£?
air filter,£
bonnet scoop as engine is tall £?
engine craddle mods£?
and im sure others will fill in,
lots of power but lots of money,
good luck though
nice engine
Indy bird thanks
i've had a look, any chance you could take some pics of your chassis/engine mounts please
also where abouts is the gear change linkage is it bulkhead side
engine cost... i'll have my engine package for sale so should offset most of that
hi
car runs paddle shift with a cable so not sure about which side it ould run,
this has a bracket on the drivers side bulk head for opperating the leaver,
can do some pics once i get the engine re installed, getting the new enigne tommorow from malc,
the engine mounts directly off the passenger side chassis rail same as zx12, i am not happy with the craddle and mounts so will be altering them once
i get the engine in,
also run a reverse box and the angle looks a bit much so need to alter this,
if you u2u me your email i will send once i get the chance
thanks
sean
Nice one Sean
i'll u2 my email addy
i've been reading up on Pauls website(paublo999) some good info on angle of prop and the engine, i think he managed to get the airfilter under
the bonnet but later on did fit a scoop as it was a tight fit
cheers
john
Ive got some photos in my archive.
If u want some recent ones let me know.
Any questions please ask.
Dave
Hello,
Have many pictures off making new mount for a zx14 made the swap after my zx12 blown.
Let me know i can send you in the emaill but i think a cd is better.
Big files and many pictures.
Just u2u me your adress and i will trow in the mail tomorrow.
Daniel
Dave, i've had a nosey at your archive photos
i'll most likely have 1000 questions if i go ahead with the conversion
Daniel that would be great, i've not seen an zzr1400 in an mnr chassis. so yes please i'll u2 my email
