Neutral has disappeared
When the engine is on and you go looking for neutral, its not there. Turn engine off and it's easy. What's likely
to be causing this?
Dragging clutch?
I was going to say that !!
i presume its a hair drier engine ??
Has it always been like this or has it suddenly changed?
Not an uncommon problem on some bikes.
Could just be some slack in the selector mechanism. Check the cable / rods first. Quite often if its too sloppy, youll never find the half gear.
Like everyone else suggests -
Clutch adjustment is the most likely issue.
Chet
