ive been offered some carbs for my zzr1100 engine which are the same as mine and have been freshly dyno jetted and balanced and working fine on the
donor bike.
if i bought them and put them on my car should they run ok?
or will it need balancing again?
they are exactly the same mopdel carbs.....
cheers
dave
[Edited on 2/11/10 by jossey]
As no two engines breath exactly the same they will need re-balancing, but, shouldn't be too far off.
cheers pete.
ill just get mine balanced then i guess.
just need a balancing kit now :O)
cheers
dave
I've got a set if you fancy a whizz over to Sheffield, near M1 J31
a loan would be great if you dont mind.
:O)
cheers
im heading up past you tommorow about 3pm ish. if any use?
cheers
dave
