what type of cat does my 2008 R1 need?
-matt - 15/1/11 at 10:48 AM
as title what sort of cat does my 2008 R1 require for emissions?
is a standard 200 cell like this one fine? UNIVERSAL PERFORMANCE CAT CATALYST CATALYTIC CONVERTER on eBay (end time 09-Feb-11 11:47:49 GMT)
i will be welding some sleeves onto it to make it easy to remove, so it doesnt permanatly steal power.
cheers
Davey D - 15/1/11 at 11:00 AM
i used one similar to that on my 06 R1, it worked just fine . I had to really lean out the mixture too to pass the emissions test. but thats really easy with the power commander
adithorp - 15/1/11 at 12:39 PM
You should be OK with that. 400cpi is standard, 200 is performance cat and will work OK, giving better flow. There are some 100cpi high flow ones but they're a bit marginal for the test.
-matt - 15/1/11 at 01:13 PM
thanks, i will go with this then.
