how do you access the ecu fault codes on a busa? Do you need a set of bike dials from the bike the engine came from and a dealer mode switch? I havnt got issues with the car but one day you never know. Be nice to have the bits there if i need them. How is this all connected together?
as i understand it you need the standard clocks this gives you a rough idea of fault codes
Search for a member called (cosmick) he helped me with my gsxr 1000 he knows quite a lot about these suzuki engines send him a u-u.
what he dont know aint wort knowing!
If you've got the clocks you don't need the switch, it's a question of earthing one of the wires, the Haynes manual has the info you need (if you've got the clocks, that is)
You defo need the Busa clocks mate,
Chris
You can do it without the clocks search on the WSCC forum. I have previously posted on there how to do it in the Technical section.
http://www.ecueditor.com/
The above link will take you to the software you need
http://www.activeboard.com/forum.spark?forumID=99460&subForumID=392256&p=2
The above is the forum for the software
ok guys cheers. Will look into it
seems a 1999 engine is not accessible.. ah well maybe there is a way somehow
