Hayabusa Oil Cooler
fimi7 - 1/2/11 at 02:33 AM
I am building a MK Indy with a 08 Hayabusa.
What oil cooler size should I use? Rows, width. Looking for some guidance.
bob tatt - 1/2/11 at 07:06 AM
looking at your location i imagine it gets hot so the bigger the better mines a 36 row double core and works great even on track.
noc231073 - 1/2/11 at 07:48 AM
do you need a cooler that big???
i just got a cooler that twice the width but half the rows of the original
Due to the location iam fitting it i need the space ...
will this be enough cooling
[Edited on 1/2/11 by noc231073]
MikeFellows - 1/2/11 at 08:32 AM
im using the standard busa cooler
without hijacking, is there any reason why i shouldnt?
Jon Ison - 1/2/11 at 09:12 AM
Have a 13 row cooler mounted in front of radiator, oil temps stay in tolerance even during 1.5 hour non stop run around Cadwell.
fimi7 - 1/2/11 at 10:15 AM
Really concerned more about track use than day to day driving. Was planning on replacing with a 16 row, based on the stock one being 15 (I think, need to count it again).
36 seems a little overkill, but maybe thats the radiator and not oil cooler.
Thanks for the input.
prawnabie - 1/2/11 at 12:04 PM
Put a thermostatic valve in and use the biggest you can fit in!
