Hi guys can you run an r1 engine without the clocks connected ??
Drew
Dont see why not. You definetly can with the ZX9.
Yes - the carb model (upto 2001) is very easy to run without the clocks. The injection model (2002 onwards) is harder without the clocks but it can,
and has, been done.
Regards
Chris
oh well....that sounds positive.....fingers crosssed then....
hey drew..get the kettle on.i'm heading over...!
Well its up and running big thanks to colimbiman the (wiring wizard)
thanks again mate.
no worries buddy....wouldnt have happened without the kettle on.....
colin
p.s......really need to learn to spell my name.......
On a lighter note
keep up the good work. Who wired the kettle up by the way ?
http://www.colibrilighters.co.uk/
[Edited on 5/7/04 by Peteff]
Hi everyone,
Please could someone explain what the problem with running an injection R1 engine without its clocks is. I assume a 2003 engine would have this
issue?
How can these engines be persuaded to run with no clocks?
Thanks in advance
Sam
