where can i get hold of a
cam chain adjuster locking tool
for a busa? how does it fit? looking at the manual cant quite see how it retracts the push rod and holds it.
thanks
There is no locking tool for a Hayabusa cam chain tensioner. If you want to retract the tensioner, take the middle bolt out which has a spring behind it. Then remove the 2 outer bolts to take the tensioner off. Inside the tensioner is a sprung loaded toothed ratchet. Push the spring back with your thumb and retract the tensioner all the way back. Assemble the cams in the correct position and refit the tensioner. Finally fit the spring with the centre bolt and the tensioner will click forwards taking up the slack.
If you have this type of cam chain tensioner, BEWARE. This was subject to a recall and should have been replaced. The new type tensioner is nothing like this anymore and is backed up by an oil line with oil pressure to keep it quiet.Therefore, please check and tell me what you have fitted.
