R1 Turbo Exhaust
001Ben - 8/4/11 at 03:48 PM
I have got my turbo on the car and im now looking at different exhausts that i can use. Ideally I want an exhaust that would allow me to do track days and one that doesnt restrict power. Currently it has a standard r1 exhaust but i have heard they are restrictive (never had another exhaust on the car). Would the cbs exhaust below be a better exhaust for the car? or should i just save the £250 and use what i have.
current exhaust
CBS exhaust
[Edited on 8/4/11 by 001Ben]
locoR1 - 8/4/11 at 04:29 PM
You defiantly don't want to be using the R1 can would be to restrictive, mine is a 2 1/2 inch straight through silencer and very quite.
You will be amazed how quite your car will be with the turbo on it, even the induction noise is quite compared with a conventional bec running a foam filter.
matt_gsxr - 8/4/11 at 05:11 PM
Ditto the above.
I haven't got above 7krpm with my new turbo build, but it doesn't seem to be too loud.
Running a 2.75inch downpipe, that reduces to 2.5inch and then I have a Jetex 5inch x 450mm silencer hidden in the sidepod. It seemed loud but that was all the holes in my manifold, which are now fixed!
My concern is that although the turbine takes a lot of the noise pulses out of the system, once the wastegate is wide open it stops doing that. This effect is noticeable at fast idle. So, noise test will be fine as long as it isn't when at full chat.
I had a 2inch silencer (MK one) which previously served me well, but it was a little too long and I needed the exhaust outlet to line up with the hole in the bodywork.
Matt
001Ben - 8/4/11 at 05:12 PM
Thanks Dave, i thought that would be the case. Who was your exhaust from?
Has anyone used the CBS exhaust? is it any good? can anyone recommend any other suppliers?
welderman - 8/4/11 at 05:17 PM
I ran my turbo blade for a bit without a silencer at all. It did frighten old ladies when it back fired though lol
locoR1 - 8/4/11 at 05:21 PM
Fairly sure mine is from custom chrome, came out of a bargain bin at autosport a few years ago £40 rings a bell so nice and cheep.
locoR1 - 8/4/11 at 05:24 PM
Yup did the same at santapod to see if it made any difference, It didn't apart from sounding crap at idle
Was told by a few mates it sounded just as quite down the strip!
ashg - 8/4/11 at 06:19 PM
907 did mine for my turbo motor. put titanium innards in it too welding is very good as well as the general construction
001Ben - 8/4/11 at 09:17 PM
that looks nice Ash. How much was it?
cerbera - 8/4/11 at 09:41 PM
I can second 907s work
001Ben - 9/4/11 at 07:25 AM
Sounds like 907 is the buy i need to talk to
