Morning
One more job to do to get the speedo working is mount the sensor on the prop shaft, has anyone got any pics of how they have done this? I am using the
original clocks off the bike and the senor etc are all intact.
Any pics or instruction on this would be great
thanks
I have the sensor mounted onto an aluminium bracket on the engine cradle and pointed at the bolt heads on the prop adaptor. Works fine for me. You'll still need the speedo healer type device.
Like the one at jaycars? For £20 also do you have a pic handy?
[Edited on 18/4/11 by gavinpurvis]
I had one of them from Jaycars, big thing it is about 6"-7" long and it played up then stopped working at SVA so got thrown in the bin. I
got a Healtech speedo healer off Ebay. I have the V.1 and a quick look shows only V.2's there at the minute, which are fine but a litle more
expensive, being the latest version. They're all basically the same thing but with a different loom so I just bought any.
I don't have a picture of the bracket with speedo, I'll have to try later as I've to go and pick err indoors up and have my ear twisted
about something.
That's has good as I can get mate. You can just make it out bolted to an aluminium bracket reading the prop adapter bolts.
