Under the carbs on the engine there are 4 bolts currently there are pipes coming off the 2 end ones - should pipes be coming off the 2 middle ones as
well?
see
[Edited on 3/5/11 by gavinpurvis]pic
you'll need to upload that pic to your archive first
Off the float bowls or block itself???
link to flickr added
Can't really see the pic very well mate. Ian viewing it on my iPhone which prob don't help
i couldnt get the best pic, that is of the pipe coming off the end hole the bolt head you can see is the next one along with no pipe coming off.
They're for the carb balancers. I have 2 of them joined together too by a pipe. Can't remember just now which two.
ETA Just checked and I have the outer two joined by a pipe and bolts in the middle two as the Haynes manual says.
[Edited on 3/5/11 by mistergrumpy]
Thanks that's the same as mine so nothing to sort there.
