Im now even more confused....
Ive just realised that the busa has a hydralic clutch (yep genius)
having done a little bit of research tonight it already has a slave cylinder on the engine but im struggling to see how I can take the pedal force to
the clutch without adding another slave cylinder?
what have other people with hydralic clutches done?
You will probably need to do something like this. Space the slave away and fit a longer pushrod then use a small master cylinder.
I have just bought new billet slave cylinder from Nova Racing
http://www.novaracing.co.uk/hayabusa-slave-cylinder.htm
Very very nice item designed to give better pedal feel than a "spaced" original item. Cost me all in£110.40 inc plus £20 for piston seal,
spring and bleed nipple.
For clarity, this is designed to completely do away with your standard slave cylinder.
Jason
Looks nice but how is it supposed to be better than a standard spaced one ?
Thanks Guys - much appreciated.
Ive Emailed Nova Racing to see if this fits an 09 Busa engine if it does it solves a few problems I guess. What size master cylinder did you go
for?
Mike
Mike, it appears and I have been advised you want a smallish master cylinder. I have ordered a integral reservoir 0.625 master cylinder.
http://www.rallydesign.co.uk/advanced_search_result.php?keywords=master+cylinder&osCsid=krho0qammphei19ohrl1jm7hk4
The 0.625 is £28.50 and little down the page.
As to why it is better than standard, these have been redesigned to run at different pressure which apparently gives better feel when fixed into a
car. My in being fitted this week so cant comment any more than that
If you go this route you will need 3 other parts numbers for the piston, spring and bleed nipple. I have these if you decide to go for it, they are
the 3 other parts I mentioned you need.
Jason
As to why it is better than standard, these have been redesigned to run at different pressure which apparently gives better feel when fixed into a car. My in being fitted this week so cant comment any more than that![]()
If you go this route you will need 3 other parts numbers for the piston, spring and bleed nipple. I have these if you decide to go for it, they are the 3 other parts I mentioned you need.
Jason
Ive pretty much ordered everything I need so will take photos of it all when everything comes sometime next week if thats any use to you?
ive just re-read this and think your on about the master cylinder, if you do want these photos let me know and I will sort
Mike
Mike
should be with me sometime next week
when it arrives I will take some photos for you and then again once fitted
Mike
got everything i need this morning
I will get some photos of it tonight for you before fitting and then have a go at fitting it and take some more
Jason
Why reinvent the wheel, use what others have used and its proven. I bought mine from SBD Motorsports, not cheap, but the quality is very good. I think
you can get it from Nova too.
I am using a tilton .625, a couple guys over here in the states are using the same setup without issue.
thats exactly what i was posting picstures of
no re inventing the wheel here
Originally posted by fimi7
Why reinvent the wheel, use what others have used and its proven. I bought mine from SBD Motorsports, not cheap, but the quality is very good. I think you can get it from Nova too.
Davie, to some extent I agree with you, for some of us that are not as creative (namely me), a few items I just refuse to make something myself.
Again, I agree with you
, the only issue is when the gimmick you come up with fails and leaves you hanging on the road. I had a ford Anglia that did
that to me a few years ago with a slave cylinder mount failing, I guess once bitten, twice shy ..
The design in the picture from Davegtst with the ali plate looks good, actually very similar to the nova/SBD part.
The clue is in the site name "locostbuilders". The fun/challenge for me is coming up with the best solution for as little money as possible. It's nice to be able to say that you made something yourself rather than ordering it from "generickitcarparts.com"
Just my thought on the subject
Davie
I brought a steel backplate from westfield to mount the original and that split ,twice . So if you do make your own make sure its got some thickness
Mine cost me zilch.
Used the clutch cable that was used on the blade engine, knocked up a lever from bits in garage, been on car for over 2 years now and aside from a
Rose joint (used as the pivot) it's been trouble free, the joint only failed as it was well used prior to becoming part of the clutch set up.
Locost enough ?
