Hi
have just replaced my clutch plates on my R1 and am not sure if i have got it all put together correctly so just want to check with the clever
bods.
I have a barnett plate installed and want to know how much it should move with the clutch pedal pressed. I have had the engine running with the oil
cap off to see the barnett plate moving - with the pedal pressed the plate moves a little bit and continues to spin - is this correct ?
thanks in advance
