what dry sump
noc231073 - 12/9/11 at 09:20 PM
going to fit a dry sump to my busa engine .... any suggestions ?
extreme? sbd? nova?
was leaning towards the sbd system?
fesycresy - 13/9/11 at 07:15 AM
I would go SBD, simply because the don't use hoses from the scavenge pump to the pan.
Nova supply pumps to Radical I believe, but a fair bit cheaper if you go that way.
noc231073 - 13/9/11 at 07:46 AM
yeah the sbd system is about 200 more expensive than the others ...but i think i can buy hose and fitting cheaper than £200
My plan was the dry sump kit from extreme which includes 3 piece tank and baffle..
just beacuse i like the guy on the phone loads of information and knew his stuff
water pump and slave cyclinder from sbd .. because sbd supply a fitting kit with the cylinder and there waterpump is smaller that the davies pump extreme supplies .. and i have had a davies pump fail before on me ..
franky - 13/9/11 at 09:07 AM
Extreme get their stuff made by nova, why not cut out the middle man?!?
