919 blade advice
tony.g - 15/9/11 at 09:59 PM
I have got to strip and rebuild the gearbox on my 919 blade.
Is it a total engine strip or can you just strip the bottom end and split the crank case?
Benzo - 16/9/11 at 01:04 AM
you can split the crank case.. i am doing mine at the minute swapping a box over into another engine.
ReMan - 16/9/11 at 10:55 AM
You "just" split the crankcase.
Only the selectors can be removed (fiddly) without
