Im after a sump baffle for my 08 R1, Ive searched ebay Etc, but can only find up to 07.
so can anyone tell me where i can get one from?
and secondly, how hard are they to fit?, it will be done from under the car on stands.
cheers
Shouldn't be a prob to fit. Ab performance linky thingy lists for 2008
cheers D
http://www.abperformance.co.uk/products.aspx?cat=12
Martin (nitram38) on here sells them too and its who i got mine from. The one for 07 is the same for 08.
Cant comment on the fitting as not got round to doing mine yet. and my engine is out of the car.
Quick question, what liquid gasket brand are you using?
Excellant, i will order one off a-b then.
Is it litterally a case of, remove sump, place baffle in sump (does it just push fit with no bolts etc?), then refit sump?
or is there more to it?
as for liguid gasket( for refitting the sump?), whatever is in my box, not sure on the make.
cheers
