Now I have got the gearbox working fine I'm wondering whether to fit the Klicktronic that I inherited with the car.
I have the actuator and the control box, also have two push buttons with the old steering wheel. I can easily put the switches on the new wheel. Where
could I get a lead as the wheel obviously has to go through 1.2 turns each way from the centre, curly lead or may be down the centre??
Any thoughts......
demon tweeks do some although there only listing 12 or 22 core and you only need 3 core
http://www.demon-tweeks.co.uk/Search.do?method=delegate&n=1766&g=8226&s=coiled+cable
or get these thats what i did not cheap but proper bit of kit
http://www.flatshifter.com/flat-shifter-paddles/
I had one on my last mnr R1. It was fantastic. It had the curly spiral cable which did wrap around the column on full lock
