Just wondering if there is any way a carbed R1 is going to fit under the bonnet of a 7 (without cutting it), with air filters, stock sump and healthy
road clearance? Does anyone have the height of the R1 in it's orientation in a Seven?
Thanks.
45 mm below the chassis and send me a proper email addy and I willl pop some pics in for you. The air box gets turned upside down But needs modded cause one of the carbs intakes is off set.
