I have an oil temp gauge with sender and T peice. Where on the R1 1999/2000 model do I put this? Also with the water temp gauge where do I put the
sender bits?
Sorry I have very little know how here.
Cheers all.
On that engine you've really only got a couple of options for an accurate oil temp reading, you can either tap into the sump or use a sandwich
plate on the filter. I ended up using a sandwich plate with a small filter which had tap offs for oil temp and pressure as in pic below:
sandwich plate
For the water temp I used an inline adapter you can just see above the carbs
eng
I was thinking sump but the plate idea is really good. Would this be an eBay job.
Yeah it was one of these:
Oil Sandwich Plate Universal Fit gauge sender silver | eBay
I did have to file a fair bit off around the circumference to get it to fit.
Awsome info mate, brilliant thanks.
I have an oil temp gauge to put on but what other gauge on oil is most important?
Oil Sandwich Plate Universal Fit gauge sender silver | eBay![]()
The other take off is for oil pressure, I would say along with water temp the most important gauges to have.
On the sandwich plate I had to file off so much I only have the inner rub er seal between he plate. Will that be OK.
Mine was the same, I,ve had it running for an hour or so with no issues. I cant see it being an issue as long as the 1 seal is in good shape.
Fitted it today and ran it for 1/2 hour no issues.
Game on! Just need some good weather.
