As above, i've come across http://www.magnaflowstainlesssteelexhausts.com/91004-universal-cat-51mm-id.html
as i need a 2" inlet/outlet.
Would a 200 cell get the emissions down for a MOT test?
The one i bought of ebay was a 400 cell but the inlet/outlet were different sizes so sending it back! as without welding it i won't get it to
fit
[Edited on 2/3/12 by Johneturbo]
Hijack on this
My TT was made in 1994, so just catches the emmisions but has the highest limit.
Early CAT's are I am lead to believe quite restrictive so what is the cell density all about, do I want the lowest cell count in a large
container to get the best performance?
Cheers Mark
Lowest cell count would be better for performance i guess, but how low do you go, there are 100 cell counts available but would it pass emissions :/
my blackbird turbo carbed had a 200 cell and passed emmissions in the end ok, 2 attempts though,
i have a 2.5" outlet one though.
I passed SVA with a 200cpi cat on my R1.
Thats good to know guys
The more i look into it 200 cell is normal for most cars.
with the engine being injection and being able to mess about via the PC5 i should get it to where it needs to be
I think the critical thing is making sure they are freaking hot for the test
Pretty sure mine's a 200 cell and I just passed IVA yesterday. Yes, it needs to be very hot - not difficult when you're running it at 3k rpm
for quite a while in the bay!
I found the biggest difficulty was maintaining steady fast idle - the readings on the meter fluctuate around a lot with very minor variations in
throttle. In the end mine was CO 0.03, HC 115 and lambda 1.02. I ended up with the Power Commander set to -27 on the relevant bits of the map.
