Strange one, got a digi dash so can see volts.
Out for a run today and warning light started flashing, looked at readout it was down to 12v.
If I switch headlights on it goes straight back up to 12.6 then when I switch them off again it goes uo to 13 ish where it normally sits.
Then sits like this at low revs but falls again once revs rise, left ticking over it's fine.
If at any time I use power, switch fan on or lights it goes back up ?
Prob not explained it very well, basically at low revs it's fine but only normal at high revs if load is applied ?
