hi all. does anyone know if i get an ecu for a 2008 cbr1000rr from america, will it mean i don't need to have correct ignition / key etc? would like to keep it simple wi no immobiliser if i can. cheers!
Best Person to speak to is Malc from yorkshire-engines
Give him a u2u
[Edited on 3-4-12 by Kev99]
cheers!
personally I would speak to Andy Bates @ AB Performance..
http://www.abperformance.co.uk/
very knowlegable chap!!!!
Yes
There will be no hiss on the American but bear in mind the ecu pins are different so you need the loom or modify the British.you will also need some
gadgets together the American ecu to run full power as even their full power model makes less than a british. Give me a bell on 01449 736633 if you
need more info
thanks all, will have a think about it!
