Whilst working through my "to-do" list yesterday I got to the job of sorting my leaky sump. Went to take out the low oil sensor and both the
threads are buggered.
What is the concensus on this, Am i better replacing the sump or would a helicoil repair be ok? I'm just a little wary of a thread repair on such
a critical bit.
Btw engine is a 99 R1 4xv lump.
Hi
Make an aly plate 1/8" thick the same size as the sensor, drill the holes right through, use stainless steel bolts heads inside the sump Nylocks
outside with a gasket between , Job done.
Good luck
René
