since most of my knowlege is relevant to cars and ford engines in particular
im a bit lost when it comes to BEC's
mainly the transmitions
whats the best way to get the power from the bike box to the wheels?
do you use a chain or modify the box to take some sort of propshaft?
and are you still able to use the rear axle from an escort/capri/cortina?
Hi
Gearbox sprocket is changed for an adapter to take a small prop to either a centre bearing or a reverse box, then from that to the diff/back axle.
Most diff units can be used i.e. Escort, Cortina, Capri, Sierra etc... but you have to be careful of the ratios or your first two or three gears may
be redundant! No worries re. gearbox as bike engines have one built in, 6 speed sequential at that!
Chris PTM
yeah i am definatly liking the idea of sequential gears via buttons on the steering wheel with one of those shift kits
You really need to converse with Jon Ison or Jasper as I'm the Luddite of the group! Give me x-flow and twin 40's anytime (until I say different!!)
Chris PTM
lol tell me about it good ol ford engines
my current project involves a 16V RS2K I4 engine and twin webber 45's
i scrapped all the EFI crap
