How do.
I contacted a seller on ebay regarding a speedo healer for a gixxer 1000 k6 in my indy. He said it wasnt suitable for car installations? Is that
correct? It was the v4 model healer. Has anyone else had problems using the healers?
Rog
Worked fine for me, I calibrated it using the speed dispalyed on my sat nav, there is a page on the speedohealer website that works it all out for you.
healtech v4 are what most use to caliberate clocks.i prefer standalone dash so sold 2 a while back!
contact malc at yorkshire engines,he may have some kicking about!
Cheers for the feedback guys. I will try malc. Thanks
there is only a bike speedo healer and my one works perfectly in the car. Are you using the standard speedo in your dashboard? If so, the position I took the readings from was the 4 bolts on the front propshaft adapter using the genuine Suzuki speedo pick up.
you can get healers for the honda s2000 motor. i had one before i got the dash2. yellow jacket i think it was called
Ya, im using the standard k6 clocks. I havent mounted the pick up yet, i was planning the same place you mention on the front flange. What sort of gap do you need to get it to read?
speedtuner make a speedo healer for gsxr's i had one. not that it matters.
