I wanted to sort out the loom on my car. My plan was to separate out the engine loom from everything else and shorten up some of the wire runs. however I need a generator and rectifier corrector. does any body know a good source?
I just replaced mine with male and female connectors bought from car builder solutions, they do a kit with various connectors, pins and crimp tool. Tidied loom up nicely and all still going strong 2 years later.
Solder connections with heatshrink sleeving
no connector to crud up & give you problems later.
