How do
I am nearly at the point where i will need to get the PC5 set up on my indy. Im running the gsxr engine. I live in the northwest. Just wondering if
anyone knows if there are any places in the northwest who can set up the emissions for the IVA? I have fitted a Cat in the exhuast system. I know of
other people who set these up but not that local to me. Can ya recommend anyone?
Rog
Using the ZZr1400 engine we just lean off the low throttle (below 5%) until the figures come right, any local MoT station should be able to help out as long as you understand how to control the Power commander. The difficult one is the lambda figure & although we have several similar maps it may still need a "tweak" actually at the test as stuff like temp & air pressure can cause minor variations - we don't use a lambda sensor BTW, just simply map for the right emissions at idle & fast idle (2500 - 3000) HTH
