A well known Bonneville class record holder is interested in using a Hayabusa powered Fury to set some new records in 2013.
I have a real 235 HP, 1441 Busa with TTS OD gears built by Bob Carpenter ( USA Busa Expert ) for the engine.
We are now looking at a custom quick change diff.
Can anyone tell me the fastest known top speed for a Fury?
Chet
I would guess and say Ruari's cossie engined car was the fastest Fury. Over 150mph I think.
Hi Claire,
Can you please share your experience with the Fury's handling at very high speed?
Does your car have any aero additions?
Car weight / balance / rake ?
Any suggestions to improve performance would be very helpful.
Chet
[Edited on 6/4/13 by Chet]
Originally posted by Chet
Hi Claire,
Are you sure you're prepared for the answer!
) I'm willing to risk the question to Claire because
1. To the best of my knowledge only a few people have been over 150 mph in a Fury ( soon to change though - LOL ) &
2. I'm safe here in the USA
Chet
You can see the above mentioned car here:
https://www.youtube.com/watch?v=_dmvPHeOyV8
On the straights it's doing over 140 rock solid without even trying.
that cars for sale i think!
I've never maxed mine out but I've been to 140 and still accelerating a couple of times (gearing should take it to just under 150 @ rev
limit). It starts to feel a bit (lot) light on the steering but stable. The back edge of the bonnet lifts a bit with the air pressure under it.
Running an 06 R1 though a Freelander diff'. 550kg split F49/R51% Aero wise... a full floor, rear diffuser and a couple of corner splitters on the
front arches. The splitters did make it feel more planted at high speed and in long fast corners (all subjective though).
im just waiting to max mine out! im also on a freelander diff with quaife atb, but a bit less power with the blade motor.
it is however a 50mm lowered race cahassis, and is circa 430kg
Hi Claire,
Chet
Whats the record/class he wants to go for?
surely a fury should go much faster than 150+mph if a brick 7 clone and do 155+?
FYI
Current Bonneville Records
Unblown Gas Modified Sports = GMS/
Engine size = 1.01 to 1.5 = H
Current record = 165.444 mph
Engine size = .76 to 1.0 = I
Current record = 150.181 mph
The I class record looks interesting.
Chet
[Edited on 7/4/13 by Chet]
My Phoenix did 163 at Spa (geared for 170) according to the GPS datalogger....but it isn't a Fury lol.
