Hi Folks
A mate of mine turned up with this yesterday...
Was just wondering what peoples views on the most reliable engine/gearbox options would be best.I know theres quite afew bec Rascals been made over
the years but even after a diet I reckon its still going to weigh about 700kgs so I'm not convinced its the best way to go,although I do think it
would be comical to have one screaming away!
Its also been suggested that there's a chance of the Suziki Swift gti engine may mate to the box in one of the Suzuki Versions of the van?
Any views or suggetions or even experience before he starts ploughing money into donor parts,that may not be up to the job would be appreciated,as
although we've been involved in many projects over the years neither of us have really tinkered with a bec
Chris
ZX10?
Haha cheers,I'd already stumbled across that one!
BMW M5 v10 engine?
One of these Hartley V8s (made from to bike engines) should fit the bill. I'd be tempted to go mid mount tough for a bit better weight
distribution.
[Edited on 30/4/13 by nick205]
Local chap called (iirc) Dave Champion built a similar vehicle with a blown mid mounted V6. Used a blower belt to drive. I have a pic somewhere, if I
can find I'll post
Simon
Put an engine in the back and drive it backwards!
Hi, even with the original engine can wheel spin into second gear on a wet road !!! I have had several over the years.
The engine is the same one used in the SJ410. I beleve it is interchangeable with the sj413 engine which has the same block as the 90's swift gti
twin cam (100 bhp).
worst case would be get a SJ413 box and swift engine for a simple(ish) upgrade.
Offroadham, these are rwd but im all for the swift conversion, it makes more sense to my mind.abit confused as to what you said but you do think its
likely that a 1300ish 100bhp swift motor may mate to the van bellhousing all be it messing about with mix and match clutch parts.by sj im guessing
thats the little jeep.did that run a transfer box for 4wd or was it all 1 box?
Chris
completely misread the thread title, and thought, ohh one of those would make an awesome camper van type thing, doh.
Your mini nearly looks as big as my imp did next to the kitcar!
quote:The 90's swift gti engine whilst fwd was the same block as the sj413 inline block.( different sump oilpickup pipe.
Originally posted by StrikerChris
Offroadham, these are rwd but im all for the swift conversion, it makes more sense to my mind.abit confused as to what you said but you do think its likely that a 1300ish 100bhp swift motor may mate to the van bellhousing all be it messing about with mix and match clutch parts.by sj im guessing thats the little jeep.did that run a transfer box for 4wd or was it all 1 box?
Chris
Cheers for the info. Seems he's hell bent on a bike engine though!
