Hi guys just decided to go bec and was just wanting your recommendation for reversing the car. Has anyone made there own electric reverse??
It is a locost so a reverse box is probably out unless someone know where to get the cheap
"Reverse ??? Which way to go"
Backwards?
I made my own. If you look in my archive, lots of info,if you need any more, U2U me
Backwards?
Backwards?
If you hadn't said it I would have.
Hello,
I purchased a reverse gear sprocket from MK and a mk 4 golf starter motor from eBay.
I fabricated a few brackets and welded them in place. Cheap, easy and lots of fun learning how
to weld.
Check out my YouTube vid
http://youtu.be/7GfBVKb60Fg
I've the starter motor and ring gear that was bolted to the sprocket on the Global just sat in a box that I'm happy to sell. There is a bracket too that was used to mount it. If interested I can get a load of photos for you.
Ahh found you Andy.. thanks for posting that video on youtube, i did comment on it..
i did an exact replicate of your vid with the same items..
i can verify that it works..
thanks again
thanks again
